Dear Sir
I refer to the IMX6SDLRM Rev.4.
P4516 51.5 SNVS Regulator
If VDDHIGH_IN is present, then the SNVS_IN supply is internally shorted to the VDDHIGH_IN supply.
VDDHIGH_IN can be separated from SNVS_IN by setting the PMU_MISC0[discon_high_snvs] bit.
P910 CCM_ANALOG_MISC0n field descriptions (continued)
discon_high_snvs : This bit forces the short between VDDHIGH_IN and VSNVS_IN to open when asserted. This is useful in power cases where SNVS_IN > VDDHIGH_IN.
I refer to the schematic of MCIMX6DL-SDP (SPF-27417_C5.pdf).
VDDHIGH_IN_1/2 = VDDHIGH_IN = VGEN5 = 2.8V
VDD_SNVS_IN = VSNVS_3V0 = 3.0V
(SNVS_IN > VDDHIGH_IN)
Q1.
Is it necessary to set PMU_MISC0[discon_high_snvs] bit when designing like MCIMX6DL-SDP?
Eishi SHIBUSAWA
Hi Eishi
your understanding is correct and more described in Table 2-6. Power and decouple
recommendations i.MX6 System Development User’s Guide
https://www.nxp.com/docs/en/user-guide/IMX6DQ6SDLHDG.pdf
This setting may be useful in battery powered designs.
However in case MCIMX6DL-SDP design SNVS_IN is powered from
pmic PMIC_VSNVS and its SNVS current provided from VIN which eventually is
powered from board external 5V/5A universal DC power supply, not from LICELL so
coincell will not be discharged to VDDHIGH_IN. Pmic VSNVS generation is described in
sect.6.4.7VSNVS LDO/Switch MMPF0100 Datasheet
https://www.nxp.com/docs/en/data-sheet/MMPF0100.pdf
