SGTL5000 I2S Slave clock configuration
次の代わりに検索
749件の閲覧回数
sumish_ks
I am working on a custom board based on imx6qsabresd where I am using sgtl5000 audio codec as slave . I have configured SSI1 as i2s-master and getting approx. 24 Mhz clock on I2s_sclk pin of codec.
I want to divide this clock and for that I have to configure some registers according to IMX6DQRM manual.
Where should I configure these registers ? I have seen some files in old kernel but these are not present in our freescale 3.14.1.1 linux kernel.
Thanks & Regards,
Sumish
ラベル(3)
タグ(2)
506件の閲覧回数
Hi Sumish
on i.MX6 Sabre SD schematic spf-27392 AUD_MCLK signal is produced from
pad GPIO_0 signal (CCM_CLKO1) GPIO_0_CLKO
Schematics (1)
Design files, including hardware schematics, Gerbers, and OrCAD files
SABRE Platform for Smart Devices|NXP
Settings for "cko" selection can be found in linux/arch/arm/mach-imx/clk-imx6q.c
linux-2.6-imx.git - Freescale i.MX Linux Tree
4 返答(返信)
507件の閲覧回数
Hi Sumish
Schematics (1)
506件の閲覧回数
sumish_ks
Hi igor,
Thanks for your answer. If I want to modify CCM registers according to our need, can I modify it using .cfg (DCD settings) file or Using memtool directly ?
Sumish
506件の閲覧回数
Hi Sumish
yes this can be changed with dcd header and memtool.
506件の閲覧回数
sumish_ks
Hi igor,
Thanks for your help.
Sumish
