SAI5_RXD3 AS GPIO3_IO24
次の代わりに検索
382件の閲覧回数
VinithNama
Hi sir,
          We are trying to configure the SAI5 pins which are available on EXP CN, we have made the following configuration.
1.Updated the mux value in imx8mm-pinfunc.h
2.Added in the imx8mm-evk.dts by selecting the pad register values.
When we are exporting the gpio from kernel space to user space and trying to make SAI5 pins high and low, the voltage of the SAI5 pins is in ideal condition(1.5).
At the same time, we have verified with the EXP_IO pins on the EXP CN connector and on board GPIO pin(GPIO1_IO13), we are using the formulae for calculating and exporting the gpio is (GPIO PAD - 1)*32+pin number. and we can make the pin high and low and confirmed using multimeter.
Can you please guide us any other configuration we are missing?
Thanks & Regards,
Vinith.
377件の閲覧回数
Hi Vinith
one can look at below gpio tutorial
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/How-to-use-gpio-hog-demo/ta-p/1317709
370件の閲覧回数
VinithNama
Hi Sir,
       I have tried your solution provided, getting the same value. Any alternate solution so please provide.
