Running FreeRTOS application from external memory i.e Board RAM
971件の閲覧回数
ranjay_shandilya
I am using IAR ide and trying to run my FreeRTOS application from sdram.
I am using .icf file provided with DSK example provided by NXP as below (attached file). But, My application crashes during BOARD_InitBootClocks() call.
Any reason?
3 返答(返信)
962件の閲覧回数
jeremyzhou
Hi @ranjay_shandilya ,
Before answering your question, I was wondering if you can describe the testing environment, for instance, the board, debugger, etc.
TIC
958件の閲覧回数
ranjay_shandilya
Hi @jeremyzhou
Board is i.MXRT1050 EVK and I am using JLink ultra for flashing and debugging
950件の閲覧回数
jeremyzhou
Hi, Thanks for your reply. Please check whether you download the SDK library for the MIMXRT1050 EVK, as the RT1050 has two versions of evaluation boards, MIMXRT1050 EVK and MIMXRT1050 EVKB. Have a great day, TIC ------------------------------------------------------------------------------- Note: - If this post answers your question, please click the "Mark Correct" button. Thank you! - We are following threads for 7 weeks after the last post, later replies are ignored Please open a new thread and refer to the closed one, if you have a related question at a later point in time. -------------------------------------------------------------------------------
