Hello, NXP technical support team:
We made a i.mx8M board with 3 kinds of DDR size: 1GB, 2GB and 3GB.
For the i.mx8M board with 1GB DDR, it can't run "rpmsg_lite_pingpong_rtos_linux_remote.bin" in DDR (not TCM).
The McuXpresso SDK we use is "SDK_2.5.1_EVK-MIMX8MQ.tar.gz".
We follow the document: "Getting Started with MCUXpresso SDK i.MX 8M Devices.pdf" to load m4 binary into DDR.
• fatload mmc 0:1 0x80000000 rpmsg_lite_pingpong_rtos_linux_remote.bin• dcache flush• bootaux 0x80000000
Then it goes to reset.
U-Boot 2018.03-00127-g10286c6 (Jun 17 2019 - 01:37:25 -0700)CPU: Freescale i.MX8MQ rev2.0 1300 MHz (running at 800 MHz)CPU: Industrial temperature grade (-40C to 105C) at 54CReset cause: PORDRAM: 1 GiBMMC: FSL_SDHC: 0Loading Environment from MMC... OKNo panel detected: default to HDMIDisplay: HDMI (1280x720)In: serialOut: serialErr: serialBuildInfo:- ATF 1cb68fa- U-Boot 2018.03-00127-g10286c6switch to partitions #0, OKmmc0(part 0) is current deviceflash target is MMC:0Net:Error: ethernet@30be0000 address not set.No ethernet found.Fastboot: NormalNormal BootHit any key to stop autoboot: 0u-boot=> fatload mmc 0:1 0x80000000 rpmsg_lite_pingpong_rtos_linux_remote.bin"Synchronous Abort" handler, esr 0x96000145elr: 0000000040201784 lr : 000000004022a808 (reloc)elr: 000000007ff13784 lr : 000000007ff3c808x0 : 0000000080000000 x1 : 0000000080004e00x2 : 0000000000000040 x3 : 000000000000003fx4 : 000000000000000e x5 : 000000000000000ex6 : 000000007ff7f0b0 x7 : 000000007ff7f0b0x8 : 0000000000000010 x9 : 0000000000000002x10: 0000000000000000 x11: 0000000000000006x12: 000000000001869f x13: 000000007e90a38cx14: 000000007e90a4a0 x15: 0000000000000002x16: 0000000000001080 x17: 0000000000000000x18: 000000007e911da0 x19: 0000000030b40000x20: 000000007e90a038 x21: 000000007e913ed0x22: 000000007e90a050 x23: 0000000030b40000x24: 0000000008000810 x25: 000000007e914dd0x26: 000000007ff8c56d x27: 0000000000000011x28: 000000000000fff0 x29: 000000007e909f80Resetting CPU ...
Then we notice the load address "0x80000000" is out of 1GB range.
So we modify the link script "MIMX8MQ6xxxJZ_cm4_ddr_ram.ld" in "rpmsg_lite_pingpong_rtos" example:
multicore_examples/rpmsg_lite_pingpong_rtos/linux_remote/armgcc/MIMX8MQ6xxxJZ_cm4_ddr_ram.ld
/* Specify the memory areas */
MEMORY
m_interrupts (RX) : ORIGIN = 0x80000000, LENGTH = 0x00000240
m_text (RX) : ORIGIN = 0x80000240, LENGTH = 0x001FFDC0
m_data (RW) : ORIGIN = 0x80200000, LENGTH = 0x00200000
m_data2 (RW) : ORIGIN = 0x80400000, LENGTH = 0x00C00000
multicore_examples/rpmsg_lite_pingpong_rtos/linux_remote/board.c
/* Select Region 2 and set its base address to the DDR start address. */
MPU->RBAR = (0x80000000U & MPU_RBAR_ADDR_Msk) | MPU_RBAR_VALID_Msk | (2 << MPU_RBAR_REGION_Pos);
We modify the address from "0x80000000" to " 0x59000000 ".
MEMORY
m_interrupts (RX) : ORIGIN = 0x59000000, LENGTH = 0x00000240
m_text (RX) : ORIGIN = 0x59000240, LENGTH = 0x001FFDC0
m_data (RW) : ORIGIN = 0x59200000, LENGTH = 0x00200000
m_data2 (RW) : ORIGIN = 0x59400000, LENGTH = 0x00C00000
MPU->RBAR = (0x59000000U & MPU_RBAR_ADDR_Msk) | MPU_RBAR_VALID_Msk | (2 << MPU_RBAR_REGION_Pos);
Then we rebuild binary and run it again.
At this time, it doen't crash with following commands:
• fatload mmc 0:1 0x59000000 rpmsg_lite_pingpong_rtos_linux_remote.bin• dcache flush• bootaux 0x59000000
But i don't see any output from the M4 debug console.
It seems there is still something needs to be changed, or anything i'm doing is wrong?
BR,
Richard
Hi, Richard Hu
I have tried to reproduce the issue on i.MX8MQ EVK board. As i.MX8MQ EVK board has 3GB DDR, I have decrease the DDR size and then run the M4 application "rpmsg_lite_pingpong_rtos_linux_remote.bin" in DDR with below commands and I am able to run the application successfully.
Can you please provide the DTS files (fsl-imx8mq-evk.dts, fsl-imx8mq-evk-m4.dts) to debug further?
Shivani
Hi Richard,
I internally escalated your request, and AE team has checked their environment as follows:
Settings in u-boot to run M4 binary are:
u-boot=> setenv m4_image audio_server.bin
u-boot=> setenv m4_loadaddr 0x7e0000
u-boot=> setenv load_m4_image "fatload mmc '${mmcdev}':'${mmcpart}' '${m4_loadaddr}' '${m4_image}'"
u-boot=> setenv run_m4_image "run load_m4_image; bootaux '${m4_loadaddr}'"
u-boot=> saveenv
Then use "run run_m4_image" to run the program.
Try if it works for you.
Hope this will be useful for you.
Best regards!
/Carlos
