Restrict kernel display driver or Android OS to use only a part of display pixels / resolution
次の代わりに検索
6,125件の閲覧回数
DiegoFSL
Hello everybody.
I've got an i.MX6SL EVK with a "MXIMX28LCD Seiko 4.3" WVGA" display running Android 4.3 beta BSP (jb4.3_1.0.0-beta). The system is working fine at native 800x480 display resolution.
My target now is to use a resolution of 240x240 on that display (so using just a subarea), so that we can design properly applications for a 240x240 display we will be using in the future, but is not ready yet at the moment.
I've tried both the "display driver way" and the "Android OS drawing way", but I haven't reached my target yet.
DISPLAY DRIVER WAY
I've looked at the sources drivers/video/mxc/mxc_elcdif_fb.c and drivers/video/mxc/mxcfb_seiko_wvga.c in the kernel and I've found that the 800x480 is selected by the call:
fb_find_mode(&fbi->var, fbi, fb_mode, pdata->mode, pdata->num_modes, NULL, default_bpp);
at line 1438 of mxc_elcdif_fb.c:
linux-2.6-imx.git - Freescale i.MX Linux Tree
which I think is the one reported in:
/sys/devices/platform/mxc_elcdif_fb/graphics/fb0/modes
But I'm not sure what's the best way to modify the source to have 240x240. I've tried following https://community.freescale.com/thread/311900 but I don't know if I can apply it for using just 240x240 of a 800x480 display.
ANDROID OS DRAWING WAY
In this case I've tried modifying method mapFrameBufferWithFbid of hardware/imx/mx6/libgralloc_wrapper/framebuffer.cpp but I got only a full white display by forcing:
info.xres = 240;
info.yres = 240;
I'd really appreciate any help to achieve this hack.
Diego
ラベル(5)
4 返答(返信)
660件の閲覧回数
nehaprabhakar
Hi Diego,
I am trying to the same for Nexus 4 device. Were you able to draw 240x240???
If yes then can you help me with the same.
Currently I have tried changing the panel info of xres and yres in kernel display driver file mipi_lgit_video_wxga_pt.c with 400x400. But only display is getting changed.
The touchscreen is still mapped to the initial resolution(768x1280).
Any help will be really appreciated.
660件の閲覧回数
DiegoFSL
Sorry for the late reply but no, I haven't spent additional time on that.
661件の閲覧回数
jamesbone
The best option, it is modifying the low level driver that handles the V4L2, just like the thread it is implemented by weidong.sunIMX6SLEVK: Custom display - 320x240@60Hz  and then change the bootargs to acknowledge the new resolution.
Saludos
661件の閲覧回数
DiegoFSL
Thank you. I've been able to use the 320x240 in this way, but not yet 240x240, as it's not a standard resolution. Thank you however for your help.
