I am using PF3001 for my application.I am few question on PF3001:
Nitesh
Hi Nitesh
-PF3001 is already preprogrammed so there is no way to
program the PMIC with your requirements
- it is programmed similar to PF3000, check i.MX7 bsp sources
- sorry, could you clarify question
Hi Igor
Thanks for the reply.
Can i program the sequencing as per my application for PF3001.
Nitesh
Hi Nitesh
no as PF3001 is already preprogrammed so there is no way to
program the PMIC with another sequences
Hi Igor
I see one I2C interface on PF3001.
So what is the use of I2C in the application.
Nitesh
Hi Nitesh
it is used for power management and cpu freq drivers
