Random hangs during resume on 4.1.15 kernel
dougjene
Hi All,
I am using 4.1.15 freescale kernel on iMX6DL board. I tried using suspend to disk feature on this board and suspend worked fine.
But when I resume there are random hangs observed i.e., sometimes it hangs very early and sometimes at the last stage of resume.
Also I see that problem maybe with timers. When I enabled "CONFIG_DEBUG_TIMEKEEPING" , I received below error messages during resume. I suspect hang may be because of improper timer resume. Please correct me if I am wrong
[ 0.005027] INFO: timekeeping: Cycle offset (4281355128) is larger than the the 'mxc_timer1' clock's 50% safety margin (2147483647)
[ 0.005034] timekeeping: Your kernel is still fine, but is feeling a bit nervous
[ 0.005039] WARNING: Underflow in clocksource 'mxc_timer1' observed, time update ignored.
[ 0.005041] Please report this, consider using a different clocksource, if possible.
[ 0.005045] Your kernel is probably still fine.
I tried 3.14 kernel and everything worked fine.
I have also tried disabling CPU freq and Bus freq but same issue occurs.
AnsonHuangigorpadykov‌
Guys please let me know your opinions
Labels (5)
Hi Doug
please refer to Chapter 21 Low-level Power Management (PM) Driver
attached Linux Manual for low power functionality supported in
nxp linux bsps. Seems suspend to disk is not supported, this may
be posted on kernel mail list.
dougjene
Hi Igor,
Thank you for the reference. But I see no problem in 3.14 freescale kernel so I posted it here. And also pm related commits are done by AnsonHuang‌ , so maybe he can help
