I am using RTC PCF2127 in our custom board. I am always getting the below error when date setting at the time of booting.
"oscillator stop detected, date/time is not reliable"
According to the data sheet this error will occur when OSF bit is set. How to clear this bit for first time reading the RTC time.
This error will not come when we write the date and try to read the same. The steps which I followed
1. Set current date using "date -s" command
2. hwclock -w
3. hwclock
Issue observed : hwclock command is not giving me the date which I have set . Any configuration is required for solving the issue ?
Please provide the input for the same
Thank you,
Sharmila
Thanks for your reply . In my case battery health is good Vbat 3.05V.
when i set the date and try to write to hwclock i get the below message
root@imx6q-dms-ba16:~# hwclock -w
rtc-pcf2127-spi spi4.1: low voltage detected, check/replace RTC battery.
rtc-pcf2127-spi spi4.1: oscillator stop detected, date/time is not reliable
root@imx6q-dms-ba16:~# hwclock -r
hwclock: RTC_RD_TIME: Invalid argument
I'm using SPI communication is there any issue in my dts file
&ecspi5 {
fsl,spi-num-chipselects = <2>;
cs-gpios = <&gpio1 17 0>,
<&gpio2 0 0>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ecspi5>;
status = "okay";
m25_eeprom: m25p80@0 {
compatible = "atmel,at25";
spi-max-frequency = <20000000>;
size = <0x8000>;
pagesize = <64>;
reg = <0>;
address-width = <16>;
rtc:pcf2127@0{
#address-cells = <1>;
#size-cells = <1>;
compatible = "nxp,pcf2127";
spi-max-frequency = <5000000>;
interrupt-parent = <&gpio2>;
interrupts = <7 IRQ_TYPE_LEVEL_LOW>;
reg = <1>;
do i go wrong in above?
sandy
The "hwclock: RTC_RD_TIME: Invalid argument" is due to driver is returning -EINVAL when low voltage is detected.
You can try with below step:
Read the control register 1 in pcf2127_rtc_set_time () function and set the STOP bit and write back the new value.
static int pcf2127_rtc_set_time(struct device *dev, struct rtc_time *tm)
//Add the below lines in the beginning of the function
regmap_read(pcf2127->regmap,PCF2127_REG_CTRL1,(unsigned int *)(&read));
read = read | 0x20 ;
regmap_write(pcf2127->regmap,PCF2127_REG_CTRL1,(unsigned int)(read));
Thanks and regards,
Sharmila
I really apologize for the delay.
Do you have the connecting of your RTC?
Probably is an error with the value of the components. The parts need to be exact since any variance could harm the integrity of the signal, giving a bad read of the time.
Please see the below application note, there you could find the schematics of how you need to connect the RTC.
https://www.nxp.com/docs/en/application-note/AN11266.pdf
Furthermore, Do you know if your RTC hardware is being seen by the kernel? Probably, the PCF2127 has not been set correctly.
Hope this can help you.
Diego.
I face the same issue i'm using 4.1.29 kernel with spi communication
I get the log as below
rtc-pcf2127-spi spi4.1: rtc core: registered rtc-pcf2127-spi as rtc0
hwclock -r
please provide me the input to solve this issue
sandy
I have faced this issue because of low voltage in RTC battery. After mounting the new RTC battery issue got solved.
For checking the date use below commands
date -s "yyyy-mm-dd h:m:s"
hwclock -w
hwclock -r
Sharmila
