RTC always reset to 19700101
搜索替代
1,576 次查看
Mihan
Hi.
I find rtc on my board doesn't work well: it can be set by "hwclock -w" , but after reboot, it will be reset.
e.g.
root@imx6qsabresd:~# hwclock
Tue Jun 20 19:15:57 2017 0.000000 seconds
root@imx6qsabresd:~# date -s 20200101
Wed Jan 1 00:00:00 UTC 2020
root@imx6qsabresd:~# hwclock -w
Wed Jan 1 00:00:08 2020 0.000000 seconds
root@imx6qsabresd:~# reboot
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 2020-01-01 00:01:19 UTC (1577836879)
...(cut off power,use button battery)
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 UTC (1)
Then I check the voltage when the power was changed, it's great. (3.29v to 3.08v)
So, are there somthing wrong in the code about rct initialization or others?
Mihan
标记 (1)
5 回复数
1,498 次查看
Hi 铭恒 李
what bsp used in the case, one can try with linux from
source.codeaurora.org/external/imx/linux-imx  repository
linux-imx - i.MX Linux kernel
For hardware one can check voltage on VDD_SNVS_CAP
with oscilloscope for possible glitches.
1,498 次查看
Mihan
I'm using 4.1.15-2.1.0.
How to check the initialization of RTC in kernel
Yes, I checked the voltage with oscilloscope before, it has the minimum of 2.9v when I cut off the power.
1,498 次查看
please try to reproduce issue on i.MX6Q Sabre SD board
with Demo Images:
https://www.nxp.com/webapp/Download?colCode=L4.1.15_1.0.0_MX6QDLSOLO&appType=license
If it can not be reproduced then issue in custom hardware, recheck board hardware design using
IMX6DQ6SDLHDG, Hardware Development Guide for i.MX 6Quad, 6Dual, 6DualLite, 6Solo Families of Applic...
1,498 次查看
Mihan
Maybe I know the reason.
I set the on-cpu RTC off in menuconfig, then the rtc could not open.
So did I use on-cpu RTC before,not the external RTC?
1,498 次查看
Mihan
I asked my friend about RTC, he said that maybe the backup area (BKP? but this is for stm32) was disable.
where should I check the RTC backup area in kernel code?
Let me explain the situation in detail.
This rtc is a external rtc(BM8563ESA),I'm using Imx6DL, kernel 4.1.15-2.1.0.
Now it’s always reset when register and read (snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 UTC (1))
I think maybe the system will check the power off status bit then it will reset the rtc if true.\
So where is the check of power off status bit when initializing rtc?
