RT685 Flexcomm design rule.
搜索替代
338 次查看
StephenYeh
Hi Sir
Does the RT685 Flexcomm feature support SPI(MOSI) and GPIO?
 If my system only needs MOSI, and the MISO/SS pin can set to GPIO pin.
317 次查看
StephenYeh
Hi Sir,
Thanks.
If I want to share the Flexcomm0 for SPI and I2C @rtos. (It needs re-initial the pin define)
Because our system have many I2C device(same slave address).
Do you recommend this design?
311 次查看
DanielRuvalcaba
It is possible to share the Flexcomm interface, but as you mentioned you will have to reconfigure the interface to switch between protocols. It will depend on the application if this can affect the desired performance.
Best regards, Daniel.
322 次查看
DanielRuvalcaba
Flexcomm interface supports the following features:
It does support SPI.
For more information, you can refer to chapter 21 of the UM.
I hope this helps, Daniel.
