RT1052 config nand flash and sdram
1,018件の閲覧回数
aaronbigworld
How should I configure SEMC to use both SDRAM and NAND FLASH?
I boot the program via QSPI and configured the SDRAM in the DCD.
The mothed of read and write used by SDRAM is OK.
However,
I use Nand_Flash_Init() to configure Nand Flash, I can read the properties of Flash (including Manufacturer, etc.), but read and write methods are not successful.
Actually,I find the problem in configuration that assign address of AXI or IP cmd.
I use MCUXpresso IDE.
3 返答(返信)
1,001件の閲覧回数
jeremyzhou
From my experience, to implement SEMC to connect the SDRAM and Nand Flash simultaneously, I'd like to suggest you implement them individually prior to merging them.
TIC
993件の閲覧回数
aaronbigworld
I remove Defined Symbols (XIP_BOOT_HEADER_ENABLE) to cancel SDRAM configuration in DCD and config SEMC pins and clock(132MHz) in IDE.
I init SEMC by function SEMC_GetDefaultConfig and SEMC_Init.
And then I init Nand by function Nand_Flash_Init. I can get Nand's Manufacturer and pages number but can not read and write.
Thank you very much. ^-^
984件の閲覧回数
jeremyzhou
Firstly, you should remove
XIP_BOOT_HEADER_DCD_ENABLE=1
to eliminate the DCD, furthermore, I'd like to suggest you figure out the cause of reading or writing failure via utilizing the logic analyzer.
Lastly, I was wondering if you can share the schematic of the custom board.
TIC
