I've been looking at changes that have been made to the RT1021 SDK 2.11.0.
In particular to fsl_lpuart.c.
In the function: LPUART_TransferReceiveNonBlocking
I noticed this code has changed:
/* Disable and re-enable the global interrupt to protect the interrupt enable register during
* read-modify-wrte. */
irqMask = DisableGlobalIRQ();
/* Disable LPUART RX IRQ, protect ring buffer. */
base->CTRL &= ~(uint32_t)(LPUART_CTRL_RIE_MASK | LPUART_CTRL_ORIE_MASK);
EnableGlobalIRQ(irqMask);
and
/* Re-enable LPUART RX IRQ. */
base->CTRL |= (uint32_t)(LPUART_CTRL_RIE_MASK | LPUART_CTRL_ORIE_MASK);
The old code used to be:
LPUART_DisableInterrupts(base, (uint32_t)kLPUART_RxDataRegFullInterruptEnable);
and
/* Enable LPUART RX IRQ if previously enabled. */
LPUART_EnableInterrupts(base, (uint32_t)kLPUART_RxDataRegFullInterruptEnable);
Why is the RxOverrun (LPUART_CTRL_ORIE_MASK ) interrupt being disabled? I'm not sure that is a good idea, especially when disabling the receive interrupt while copying the ring buffer to rxData. Won't that hide issues when the copy takes too long?
Perhaps I have mis-understood it.
Thanks and regards,
Ronnie
