RT1021: Connecting to external SDRAM with Segger J-Link
搜索替代
390 次查看
rshipman
Contributor V
I have just started using a Segger J-Link Ultra+ with MCUXpresso and I am unable to debug code that is running on the RT1021 using external SDRAM. I just get 0xdeadbeee in the debug call stack.
If I use a project that runs entirely in internal SRAM, the debugger seems to work ok.
Up until now I have been using an LPC-Link2 debugger, using the MCUXpresso LinkServer CMSIS-DAP option to debug. I have a .scp script to initialise the SDRAM which works fine.
I believe the J-Link problem is because the SDRAM has not been initialised and I need a J-Link script to do this.
If it is a J-Link script that I need, do you have an example that would initialise the SDRAM in the same way as the .scp one please? Perhaps you have one for the RT1020-EVK? That would be perfect if you do.
Any information would be very helpful.
Thanks and regards,
Ronnie
382 次查看
kerryzhou
Hi @rshipman ,
   JLINK+MCUXpresso+SDRAM, need to use the .jlinkscript file to enable the SEMC for the SDRAM.
 Please open the SDK demo code, it already contains the script file:
\SDK_2_12_0_EVK-MIMXRT1020\boards\evkmimxrt1020\demo_apps\hello_world
Then in the mcuxpresso debug configurations, add the related script file is OK.
Wish it helps you!
Kerry
379 次查看
rshipman
Contributor V
Hi Kerry,
Many thanks for your prompt reply!
Ronnie
383 次查看
kerryzhou
Hi @rshipman ,
Wish it helps you!
Kerry
