Qt applications are not proprely working (huge delay) on i.MX6UL
Search instead for
Poornesh7
We are using i.MX6UL SoC for our project . We have successfully integrated LCD to our custom carrier board and we have successfully built yocto images (Yocto : Zeus ,DISTRO=fsl-imx-wayland )for the target SoC .
But when I try to run Qt application it is very slow and I could not able to do any functionalities .
So requesting to kindly suggest me whether I need to add any Qt related packages or need to build again for any other DISTRO .
Thanks in advance
Qmiller
You should use fsl-imx-fb to build, i.MX6UL only supports Frame Buffer graphics.
Qmiller
Poornesh7
Thanks for your valuable response !
It's gald to inform you that our Qt application is working as expected without any delay after building with "fsl-imx-fb" as mentioned.
But I have other query , we have developed our Qt application with some animations (gifs) . But here these animations are not running .
Please kindly suggest me whether I need to add any extra packages for animations (gifs) to run .
