I built a test app in Qt Creator IDE and loaded it on MYS6ULL board. I got this message on executing:
error while loading shared libraries: libQt5Widgets.so.5: cannot open shared object file: No such file or directory
I put this lib in /usr/lib and besides the app, but it doesn't affect. What's a proper way to solve this issue?
Solved! Go to Solution.
Hello totalit,
Make sure that you are using the MX6ULL and it latest BSP with 5.10.52 kernel or Use the official BSP and build fsl-image-qt5 BSP 3.10.52v for QTcreator that is the QT 5.5v.
