Programming i.MX8 eFUSES from userspace
Search instead for
rohitdubey
We're attempting to write the MAC address for the ethernet from a script to be executed during initial setup. I know the eFUSES can programmed from u-boot (Fusing MAC addresses in IMX8 ) but this is tricky to do from a script. We also don't have the option to boot from serial download that Universal Update Utility requires.
I can read the eFUSES from the sysfs (ocotp module) and the OTP memory mapped registers but they don't seem to be writable.
Is there a way to program the fuses from a Yocto based linux image running on the platform?
Any guidance is truly appreciated.
Rohit
Hi Rohit
for access eFUSES from userspace one can try patches provided on
OCOTP write support on i.mx8m
Hi Rohit
rohitdubey
Hi Igor,
Thanks for your reply. The patched fsl_otp driver in the above post seems to be working well for us:
   OCOTP Shadow register reload
Thanks & Regards,
Rohit
