Programming eMMC via JTAG
Search instead for
rsk_11
I am using iMX8QXP.
My query is can we flash the binaries( SECO,SCU,UBOOT,M4 APP,AP LINUX etc)
on the target board eMMC using JTAG?
We donot have SDCard or USB connection, hence is programming of eMMC via JTAG is possible?
Kindly provide any links or documents for help if any.
Thanks!
rsk_11
Thankyou for the reply.
The readme has steps for loading ATF and Uboot. Please find following queries for the same:
1. How to load a SCU FW scm_tcm.bin ?
2. Does the given .cmm script load the ATF and Uboot in given example to eMMC on MEK for iMX8QXP?
3. On our custom board we are using a different eMMC than the one used on MEK, How to generate .cmm for a different eMMC?
Regards.
joanxie
you should already get all of information from internal team, I will close this case then
joanxie
you can use trace32 to download scfw to the board, then use uboot to download images, see the attached readme
