Hello all,
I am trying to interface the OV5640MIPI camera with our custom board running on i-MX6 solo.In our schematics below signals are coming to MIPI connector from processor:
1)MIPI_CSI_CLK0_N
2)MIPI_CSI_CLK0_P
3)MIPI_CSI_D0_N
4)MIPI_CSI_D0_P
5)MIPI_CSI_D1_N
6)MIPI_CSI_D1_P
7)CAM_PWR_EN(GPIO) from pad CSI0_DAT18
8)CAM_PWDN_3V3 (GPIO) from pad CSI0_DAT14
9)CAM_RESET_3V3(GPIO) from pad CSI0_DAT15
After that I referred many device tree files but I didn't find this pin muxing in any DTSI file which are using MIPI camera.Instead of that I found below pin-muxing in every dtsi file which are using MIPI camera:
pinctrl_ipu1_2: ipu1grp-2 { /* parallel camera */
fsl,pins = <
MX6QDL_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 0x80000000
MX6QDL_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 0x80000000
MX6QDL_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 0x80000000
MX6QDL_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 0x80000000
MX6QDL_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 0x80000000
MX6QDL_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 0x80000000
MX6QDL_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 0x80000000
MX6QDL_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 0x80000000
MX6QDL_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN 0x80000000
MX6QDL_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK 0x80000000
MX6QDL_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC 0x80000000
MX6QDL_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC 0x80000000
So my question is are this Pin muxing is necessary for MIPI camera to work ? In our schematics this pads are ued for other functionalities like UART,I2S,GPIO etc, So is it causing problem.
By referring all these DTSI files I modified my DTSI file as below:
fsl,pins = <
&i2c3 {
clock-frequency = <100000>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_i2c3>;
status = "okay";
ft5x06_ts@38 {
compatible = "ft5x06-ts";
reg = <0x38>;
interrupts-extended = GPIRQ_I2C3_J7;
wakeup-gpios = GP_I2C3_J7;
ov5640_mipi: ov5640_mipi@3c { /* i2c2 driver */
compatible = "ovti,ov5640_mipi";
reg = <0x3c>;
//pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ipu1_2>;
clocks = <&clks 201>;
clock-names = "csi_mclk";
DOVDD-supply = <&wlan_en_reg>; /* 1.8v */
AVDD-supply = <&vgen3_reg>; /* 2.8v, rev C board is VGEN3
rev B board is VGEN5 */
DVDD-supply = <&vgen2_reg>; /* 1.5v*/
pwn-gpios = <&gpio6 00 1>; /* active low: SD1_CLK */
rst-gpios = <&gpio6 01 0>; /* active high: SD1_DAT2 */
csi_id = <1>;
mclk = <24000000>;
mclk_source = <0>;
&i2c3 {
status = "okay";
ft5x06_ts@38 {
reg = <0x38>;
reg = <0x3c>;
csi_id = <1>;
mclk = <24000000>;
mclk_source = <0>;
&mipi_csi {
status = "okay";
ipu_id = <0>;
csi_id = <1>;
v_channel = <0>;
lanes = <2>;
but its giving below errors after inserting ov5640_camera_mipi.ko
ov5640_read_reg:write reg error:reg=300a |
camera ov5640_mipi is not found
Kindly help regarding this issue.
Thanks & Regards,
Shrikant
Hi shree97
MIPI_CSI_ are analog signals and not muxed with other signals.
not found error may be related to i2c miscommunication, for example on
below example camera is connected to i2c2:
linux-2.6-imx.git - Freescale i.MX Linux Tree
So it makes sense to check i2c communication with oscilloscope.
Hi igorpadykov,
I modified the DTSi file as below :
v4l2_cap_0 {
compatible = "fsl,imx6q-v4l2-capture";
ipu_id = <0>;
csi_id = <0>;
mclk_source = <0>;
status = "okay";
v4l2_cap_1 {
ipu_id = <0>;
csi_id = <1>;
mclk_source = <0>;
status = "okay";
v4l2_out {
compatible = "fsl,mxc_v4l2_output";
status = "okay";
pinctrl_i2c3: i2c3grp {
fsl,pins = <
MX6QDL_PAD_EIM_D18__I2C3_SDA 0x4001b8b1
MX6QDL_PAD_EIM_D17__I2C3_SCL 0x4001b8b1
MX6QDL_PAD_EIM_D21__GPIO3_IO21 0x1b0b0 // For Touchscreen Reset
#define GPIRQ_I2C3_J7 <&gpio4 20 IRQ_TYPE_EDGE_FALLING>
#define GP_I2C3_J7 <&gpio4 20 GPIO_ACTIVE_LOW>
MX6QDL_PAD_DI0_PIN4__GPIO4_IO20 0x1b0b0 //For Touch Interrupt
&i2c3 {
status = "okay";
ft5x06_ts@38 {
reg = <0x38>;
reg = <0x3c>;
//pinctrl-0 = <&pinctrl_ipu1_2>;
csi_id = <1>;
mclk = <24000000>;
mclk_source = <0>;
&mipi_csi {
status = "okay";
ipu_id = <0>;
csi_id = <1>;
v_channel = <0>;
lanes = <2>;
after that I load the below modules and the response is as below:
root@imx6qdlsolo:~# insmod v4l2-int-device.ko
root@imx6qdlsolo:~# insmod ov5640_camera_int.ko
root@imx6qdlsolo:~# insmod ov5640_camera_mipi.ko
camera ov5640_mipi is found
root@imx6qdlsolo:~# insmod adv7180_tvin.ko
root@imx6qdlsolo:~# insmod ipu_prp_enc.ko
root@imx6qdlsolo:~# insmod ipu_fg_overlay_sdc.ko
root@imx6qdlsolo:~# insmod ipu_still.ko
root@imx6qdlsolo:~# insmod ipu_csi_enc.ko
root@imx6qdlsolo:~# insmod ipu_bg_overlay_sdc.ko
root@imx6qdlsolo:~# insmod mxc_v4l2_capture.ko
root@imx6qdlsolo:~# ERROR: v4l2 capture: slave not found!
root@imx6qdlsolo:~# i2cdetect -y 2
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- UU -- -- -- UU -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Dmesg output related to camera:
write_reg: set register 0x00 to 0x00
set_mode: changed mode to 0x00
Also I checked the Waveforms using logic analyzer.
Also I tried with the drivers as buit-in modules but I got the same errors.
kindly give you suggestions regarding this issue.
Thanks & Regards,
Shrikant
Hi Lavanya,
The output of ./mxc_v4l2_capture.out is as below:
root@imx6qdlsolo:/unit_tests# ./mxc_v4l2_capture.out
in_width = 176, in_height = 144ERROR: v4l2 capture: slave not found!
out_width = 176, out_height = 144
top = 0, left = 0
Unable to open /dev/video0
Unable to create y frame recording file
I am unable to debug this error "ERROR: v4l2 capture: slave not found!"
Thanks & Regards,
Shrikant
Hi Lavanya,
v4l2_cap_0 {
ipu_id = <0>;
csi_id = <0>;
mclk_source = <0>;
status = "okay";
v4l2_cap_1 {
ipu_id = <0>;
csi_id = <1>;
mclk_source = <0>;
status = "okay";
v4l2_out {
status = "okay";
fsl,pins = <
&i2c3 {
status = "okay";
ft5x06_ts@38 {
reg = <0x38>;
reg = <0x3c>;
csi_id = <1>;
mclk = <24000000>;
mclk_source = <0>;
&mipi_csi {
status = "okay";
ipu_id = <0>;
csi_id = <1>;
v_channel = <0>;
lanes = <2>;
kindly help regarding this issue.
Thanks & Regards,
Shrikant
Hi Lavanya,
I tried the drivers as built in modules but still I am getting the same error as below:
Thanks & Regards,
Shrikant
