Power Save mem-mode TEST result and question.
1,380 次查看
sung-ukjang
We had finished test "mem-mode" on iMX28-EVK.
will wake up to using "PSWITCH" button on Mem-mode.
I have  some question.
1. How to check "Mem-mode" or "Power-Off" status??
- because iMX28 is RESET/ is Low status in Mem-mode.
- Can you tell me,  still using GPIO config on Mem-mode.
2.We using "PSWITCH" at wake-up source and Power On/Off source.
In IMX28EVK, long push PSWITCH for Power off. still working 32.768KHz sleep clock.
in case is more 12mA to Mem-mode.
root@freescale ~$
root@freescale ~$ release pswitch to power down
pswitch power down
is this normal case??
please help to me!!!
Thanks.
标记 (2)
996 次查看
GraceH
Senior Contributor II
Hi, Sung-Uk
If mem mode you mentioned is entered by command "echo mem > /sys/power/state", actually there is no method to check the difference of mem mode and power off mode. In both of modes,the chip is power down by setting PWD of HW_POWER_RESET.
In MX28 suspend-to-RAM mode, only DRAM is in self-refresh mode and is powered by external circuit; ARM core, on-chip modules, and PLL are off. After entering suspend-to-RAM mode, only power key can resume, then system starts a code boot.
Grace
6 回复数
996 次查看
YixingKong
Senior Contributor IV
Sung-Uk
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
996 次查看
sung-ukjang
OK,  Thanks for your support.
996 次查看
YixingKong
Sung-Uk
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
997 次查看
GraceH
Hi, Sung-Uk
Grace
996 次查看
AnsonHuang
OK, Thanks Grace, I just recalled that on i.MX28, the default mode is standby, and the mem mode is mapped to another mode that all modules are off except DRAM, please refer to Grace's answer, she is right, I forgot that I did NOT enable the mem mode on i.MX28.
996 次查看
AnsonHuang
Hi, Sung-Uk
     For question 1:
     The mem mode is sleep mode for i.MX28, you can measure the core power voltage, VDDD, there should be about 1.1V on it.
     The poweroff mode is to shutdown i.MX28, and the core's power VDDD should be very low, only some leakage.
     Not very understand your question 2, can you provide more detail?
