Playing video by gstreamer and got some error messages
charleshuang
Senior Contributor II
We have an issue about gstreamer error while playing video in the long time.
Use this command to play video:
gst-launch filesrc location=[Video Path] typefind=true ! aiurdemux name=demux demux. ! queue max-size-buffers=0 max-size-time=0 ! vpudec ! mfw_v4lsink demux. ! queue max-size-buffers=0 max-size-time=0 ! beepdec ! autoaudiosink
Error Messages:
(gst-launch-0.10:6662): GLib-GObject-CRITICAL **: g_object_ref: assertion `object->ref_count > 0' failed
(gst-launch-0.10:6662): GStreamer-CRITICAL **: gst_object_unref: assertion `((GObject *) object)->ref_count > 0' failed
New clock: GstSystemClock
[1;32m[--->FINALIZE aiurdemux
[0m
(gst-launch-0.10:6662): GLib-GObject-CRITICAL **: g_object_ref: assertion `G_IS_OBJECT (object)' failed
(gst-launch-0.10:6662): GLib-GObject-WARNING **: invalid unclassed pointer in cast to `GstAiurDemux'
Can you provide any advice about this issue?
Labels (2)
igorpadykov
Hi charles
reason may be as described in sect.6.3 Known issues and limitations for multimedia
i.MX_Linux_Release_Notes.pdf from L3.14.28_1.0.0_LINUX_DOCS
