Part Number Nomenclature of i.MX 8 and 8X
hi_shawn
Hi FSL engineer,
Could you please advise me the Part Number Nomenclature of i.MX 8&8X? Thank you.
joanxie
because these parts are still in  preproduction, so haven't released part number nomenclature yet.
EAlepins
Contributor V
Now that the i.MX 8X production is launched, could you provide the part numbering scheme? This can normally be found in a datasheet, but strangely, it is not the case for i.MX 8X... There is only the list of available part numbers, without a description for each letter. And that's a problem since for example, in the Industrial datasheet, the following two part numbers are listed with exactly the same description so we can't know what is their difference: MIMX8QX6CVLFZAC, MIMX8QX5CVLFZAC.
Thanks.
Étienne
EAlepins
Contributor V
Any help regarding this?
Étienne
