PMIC_ON_REQ state after SNVS on imx8mp
diegoperez
I am trying to figure out the first power up of the imx8mp.
I am implementing the powering of the imx8mp with PMIC PCA9450C, I want not to use ONOFF signal of the imx8mp because in my application there is not a power button.
According to the PMIC datasheet, PMIC_ON_REQ must be high to go into “PWRUP Seq” state.
  • What is the state of PMIC_ON_REQ (F22 ball of imx8mp) after PMIC enters SNVS state?
  • If state is low, Am I forced to set ONOFF low to get PMIC_ON_REQ high?
Thanks and BR.
Diego.
Yuri
@diegoperez
  Note: At the first power up, i.MX8M PMIC_ON_REQ signal is asserted when
i.MX8M SNVS voltages (VDD_SNVS, NVCC_SNVS) appear (without ONOFF button).
Yuri.
Yuri
@diegoperez
   1) the state of PMIC_ON_REQ  after PMIC enters SNVS state is not changed;
   2) it is needed  to set ONOFF low to get PMIC_ON_REQ high.
Yuri.
diegoperez
Hi @Yuri , thanks for your reply.
I don’t want to use a power button. In my application the system needs to be run after 12V main power supply is applied, without touching any button.
So, according your answer, will I need some electronic to generate a low pulse in ONOFF signal when SNVS is powered to set high PMIC_ON_REQ?
According to datasheet PMIC_ON_REQ has pull up at reset so PMIC will enable all rails, but in table “6-39 Power mode transitions” there is a sequence for the power mode “ON, first time” that says the power button is pushed to set PMIC_ON_REQ high.
Yuri
@diegoperez
Yuri.
