PLM_CTRL configuration for i.MX8QXP
958 次查看
Kazuma_Sasaki
Senior Contributor I
From IMX8DXAEC.pdf (Rev.0):
Regarding ADDR field in PLM_CTRL register.
We can select the destination module via this field.
Which module we can select at this field? Could you teach me selectable value and destinations?
Kazuma Sasaki.
标记 (2)
898 次查看
Yuri
  ADDR field is always set to default value, meaning that  we only support ISI output.
Yuri.
899 次查看
Yuri
Yuri.
898 次查看
Kazuma_Sasaki
Hi Yuri,
I appreciate your support. I understood that we don't need set ADDR field. Is it right?
Kazuma Sasaki.
898 次查看
Yuri
Correct.
