Openssl Error In Imx6ull
Search instead for
nagaprasad
Hi all,
we are using I.mx6ull for our project, having yocto version 5.10.when we try to use openssl library getting error as follows
fatal error: openssl/ssl.h: No such file or directory
Can anyone help us to resolve this error, we tried by adding openssl to local.conf file but we are still experiencing this error.
Thanks & regards,
Naga Prasad.
Labels (4)
Harvey021
Support that you do the cross-compiling on Ubuntu, you need to run this command line sudo apt-get install libssl-dev.
More details, here the link is for your reference. "openssl/ssl.h: No such file or directory" during Installation of Git - Stack Overflow
Harvey
nagaprasad
Hi @Harvey021
Please find attached the image for your reference, I am able to compile using 5.4 version but I am getting errors while using the 5.10-hardknott yocto version.
best regards,
naga prasad
Harvey021
BSP 5.10 actually included ssl.h, the screenshot below for your reference.
Can you please check if either the ssl.h included in your c file or other problems.
Harvey
nagaprasad
Hi @Harvey021
i have not found openssl folder in /opt/fsl-imx-fb/5.10-hardknott/sysroots/cortexa7t2hf-neon-poky-linux-gnueabi/usr/include/.
Could you please suggest to us if anything is missed while generating yocto image for imx6ull?
NagaPrasad.
Harvey021
Hi @nagaprasad
The command below for your reference.
DISTRO=fsl-imx-fb MACHINE=Target-Machine bitbake core-image-minimal -c populate_sdk
Harvey
nagaprasad
Hi @Harvey021
Thanks for your support.
in my ubuntu pc, libssl-dev is already installed, but when we are cross compiling it will search for libraries/include files  in /opt/fsl-imx-fb/5.10-hardknott/sysroots/x86_64-pokysdk-linux/.in this path i am not  getting library include files by default.
nagaPrasad
Harvey021
Hi @nagaprasad
openssl already included in yocto build by default. I am not quite catching what operation you were trying with openssl. According to the error, then have you tried install "libssl-dev", which will depends on your host.
Harvey
nagaprasad
when i am trying to use SSL library API in our application like SSL_library_init/SSL_Write().when cross-compiling application using cross-compiler,getting error as
fatal error: OpenSSL/SSL.h: No such file or directory
Could you please suggest us to resolve this error?
Thanks & Regards,
