At the end of the booting, I just spot the error "Bad Linux ARM64 Image magic!" which may happen when wrong kernel version used with uboot.
As with Linux 4.14.98 Kernel, please check if there is respective uboot.
Best Regards
Harvey
Hello aravinthkumarja.
This could be various ways of causing this problem.
Can you please firstly share what steps you have taken for downloading image and what images you have downloaded?
And It would be better to check terminal settings and drivers related to your input devices.
Harvey
Hi ,
Currently using the Android P9.0.0_2.2.0(Linux 4.14.98 Kernel) downloaded from Nxp
Its a Custom board with reference of sabresd MX6Q,Built and flashed the board using the sdcard .
During flashing facing below issue
U-Boot 2018.03-dirty (Mar 11 2022 - 00:08:57 +0530)
CPU: Freescale i.MX6Q rev1.3 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 32C
Reset cause: POR
Model: i.MX6 Dual Console UI Board(PFUZE100)
Board: MX6Q-CONSOLEUI
DRAM: 2 GiB
board_initPMIC: PFUZE100! DEV_ID=0x10 REV_ID=0x21
power_init_board device ===
Fû?ÀR?MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... OK
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In: serial
Out: serial
Err: serial
flash target is MMC:1
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
