Not able to create a spi device in Android 12.1
830 次查看
dgeier315
We are migrating from Android 12.0 to 12.1.   The Android 12.0 build was modified to use spi-imx.c from AN13633 (Using Enhanced Configurable SPI (ECSPI) as Slave in Linux for i.MX 8M
Series).   When migrating to 12.1, the probe of the driver returns an error code of -22.
[ 0.399225] spi_imx 30820000.spi: bitbang start failed with -22
[ 0.399241] spi_imx: probe of 30820000.spi failed with error -22
When I changed out the spi-imx.c from 12.1 for the one from AN13633, The probe appears to work, but now spi_busnum_to_master() fails.
[   88.391582] spiCtrl_init: MASTER not found
I don't see what has changed from Android 12.0 to 12.1.   Any insights would be appreciated.
#define MASTER_BUS_NUM 0
   //Register information about your device:
   struct spi_board_info spi_device_info = {
       .modalias = "PECL-master-command-port",
       .max_speed_hz = 13000000, //speed your device (slave) can handle
       .bus_num = MASTER_BUS_NUM,
       .chip_select = 0,
       .mode = 0,
   pr_debug("%s: Start\n", __func__);
    /* To send data we have to know what spi port/pins should be used. This information
    * can be found in the device-tree. */
   master = spi_busnum_to_master( spi_device_info.bus_num );
   if ( !master ) {
       pr_err("%s: MASTER not found\n", __func__);
       return -ENODEV;
Device Tree:
&ecspi1 {
    #address-cells = <1>;
    #size-cells = <0>;
    fsl,spi-num-chipselects = <1>;
    pinctrl-names = "default";
    pinctrl-0 = <&pinctrl_ecspi1>;
    //cs-gpios = GP_ECSPI1_CS;
    status = "okay";
790 次查看
Zhiming_Liu
The real bus number may change, you can try other value.
Or you can dump the real bus index when probe.
791 次查看
Zhiming_Liu
763 次查看
dgeier315
The bus numbers have been fixed for many versions of Android. What causes the bus number to change?
