No space left on device errors
搜索替代
3,219 次查看
neo1
cp: writing `/mnt/rwfs/var/lib/rpm/Filemd5s': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Installtid': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Basenames': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Group': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Sha1header': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Triggername': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Packages': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Conflictname': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Providename': No space left on device
cp: writing `/mnt/rwfs/var/lib/rpm/Sigmd5': No space left on device
cp: writing `/mnt/rwfs/var/state/dhcp/dhcpd.leases': No space left on device
cp: writing `/mnt/rwfs/var/state/dhcp/dhclient.leases': No space left on device
cp: writing `/mnt/rwfs/var/www/cgi-bin/test_cgi': No space left on device
cp: writing `/mnt/rwfs/var/www/html/index.html': No space left on device
cp: writing `/mnt/rwfs/var/run/utmp': No space left on device
cp: writing `/mnt/rwfs/var/log/wtmp': No space left on device
rebuilding rpm database
rpmdb: write: 0xbee8f524, 8192: No space left on device
error: db4 error(28) from dbenv->open: No space left on device
error: cannot open Packages index
I get these errors in the bootup logs. My SD card has lots of free space but these messages come up everytime on boot up. Any idea why?
Im using im35 based custom board running  Linux-2.6.31
$ uname -a
Linux freescale 2.6.31-207-g7286c01-svn1013 #66 Tue May 28 10:56:29 PDT 2013 armv6l GNU/Linux
标记 (1)
1,131 次查看
neo1
Solution:
In /etc/rc.d/rc.conf
change the following line:
export TMPFS_SIZE="512k" to export TMPFS_SIZE="4m"
1,131 次查看
LeonardoSandova
Specialist I
Perhaps the folder /mnt/rwfs is not mounted so you get those errors. Try creating a partition on your SD and mount this folder on this new partition.
Leo
1,132 次查看
neo1
Solution:
