New camera ISP bring up for IMX8MP
inbogus78
Dear NXP.
We need help for Camera Bring up.
We use PI6008K (ISP), PK5210N(CMOS). But do not work camera preview.
We attached files.(Datasheet, dts and mipi csi clk waveform).
we not received frame  sync and rx interrupt , guess Dphy does not working
1. frame format is YUV422 8bit
2.
          data-lanes = <4>;
          csis-hs-settle = <13>;
          csis-clk-settle = <2>;
3. Master send mipi clock is 148M
We log :
 mxc-mipi-csi2.0: Frame End events: 0
 mxc-mipi-csi2.0: Frame Start events: 0
 mxc-mipi-csi2.0: Non-image data after odd frame events: 0
 mxc-mipi-csi2.0: Non-image data before odd frame events: 0
 mxc-mipi-csi2.0: Non-image data after even frame events: 0
 mxc-mipi-csi2.0: Non-image data before even frame events: 0
 mxc-mipi-csi2.0: Unknown Error events: 0
 mxc-mipi-csi2.0: CRC Error events: 0
 mxc-mipi-csi2.0: ECC Error events: 0
 mxc-mipi-csi2.0: FIFO Overflow Error events: 0
 mxc-mipi-csi2.0: Lost Frame End Error events: 0
 mxc-mipi-csi2.0: Lost Frame Start Error events: 0
 mxc-mipi-csi2.0: SOT Error events: 0
 mipi_csis_s_stream: 1, state: 0x0
 mipi_csis_sw_reset (676)
 mipi_csis_set_params (771)
 fmt: 0x2006, 640 x 360
 mipi_csis_set_hsync_settle (760)
 mipi_csis_system_enable (702)
 mipi_csis_enable_interrupts (661)
 --- mipi_csis_s_stream ---
         CSIS_VERSION[0]: 0x03060301
        CSIS_CMN_CTRL[4]: 0x00004b05
        CSIS_CLK_CTRL[8]: 0x000f0000
          CSIS_INTMSK[10]: 0x0fffff1f
          CSIS_INTSRC[14]: 0x00000000
      CSIS_DPHYSTATUS[20]: 0x00000001
        CSIS_DPHYCTRL[24]: 0x0d80001f
     CSIS_DPHYBCTRL_L[30]: 0x000001f4
     CSIS_DPHYBCTRL_H[34]: 0x00000000
     CSIS_DPHYSCTRL_L[38]: 0x00000000
     CSIS_DPHYSCTRL_H[3c]: 0x00000000
   CSIS_ISPCONFIG_CH0[40]: 0x00001078
   CSIS_ISPCONFIG_CH1[50]: 0x000008fd
   CSIS_ISPCONFIG_CH2[60]: 0x000008fe
   CSIS_ISPCONFIG_CH3[70]: 0x000008ff
    CSIS_ISPRESOL_CH0[44]: 0x01680280
    CSIS_ISPRESOL_CH1[54]: 0x80008000
    CSIS_ISPRESOL_CH2[64]: 0x80008000
    CSIS_ISPRESOL_CH3[74]: 0x80008000
     CSIS_ISPSYNC_CH0[48]: 0x00000000
     CSIS_ISPSYNC_CH1[58]: 0x00000000
     CSIS_ISPSYNC_CH2[68]: 0x00000000
     CSIS_ISPSYNC_CH3[78]: 0x00000000
    GPR_GASKET_0_CTRL[60]: 0xffffffc0
   GPR_GASKET_0_HSIZE[64]: 0xffffffc0
   GPR_GASKET_0_VSIZE[68]: 0xffffffc0
MIPI clk output of PI6008K (ISP) is continuous mode like below picture.
Please give us solution.
inbogus78
ISP MIPI CLOCK is only continuous mode. So ,Do not test non-continuous mode.
Let me know the AP setting for continuous mode.
inbogus78
Attached dts file.
jimmychan
inbogus78
jimmychan
Please refer to the https://www.nxp.com.cn/docs/en/application-note/AN13573.pdf section 2.5 about the mode transitions.
in continuous clock mode, there may only be one LP state at the very beginning, and clock lane will always work in HS mode later. So it's better to make sensor work in LP state before enable 8MP DPHY. otherwise, DPHY may not detect the HS mode, then it can't receive data from sensor.
