Need support for SAI_RX2 issue
3,667件の閲覧回数
LydieCDO
Hi NXP support,
We are working with IMXRT1176 and we are facing some issues.
Here is the context:
Using SAI1 on IMX1176, we are currently trying to use SAI1_RX2 to receive data from a tuner (SI47952) but we only get 0.
IMX is the master, and the tuner is slave.
GPIO DISP_B2_01 is configured as SAI1_RX2
If we monitor the connection, we can see that the signal is squeeze to 0 and almost 0V (see attached picture)
We have done the test of connecting the tuner to SAI1_RX0 (instead of SAI1_RX2) and it we did get the correct signal/data.
That means the issue is on the IMX side, we think this can be a pin config issue as the DISP_B2_01 is SAI1_RX2 and SAI1_TX2 but we don't know how to force RX mode.
Here some SAI1 registry dump during transfers
tcr1: 0x10 tcr2: 0x7000007 tcr3: 0x10000 tcr4: 0x10010f3b tcr5: 0xf0f0f00
rcr1: 0x10 rcr2: 0x47000007 rcr3: 0x40000 rcr4: 0x10010f1b rcr5: 0xf0f0f00
Do you have any idea to unlock this situation ?
Many thanks for your support.
28 返答(返信)
1,042件の閲覧回数
Aubineau_FAE
But what is the value of R4261? it is O or another value, it is to ensure the i.MX force the pin to 0V.
Vincent
1,035件の閲覧回数
eric_delanghe
Hi again,
R4261 is a 0ohm, it's here to cut the lane and re-route if something goes wrong in the design.
Eric
1,026件の閲覧回数
Aubineau_FAE
OK, so if an th RT is driving its pin low it cannot really be detected as it is a direct short circuit.
If you configure this pin as a GPIO, in input mode, do you still have the issue?:
Vincent
915件の閲覧回数
eric_delanghe
If I configure DISP_B2_01 as GPIO5_02 the level is correct on the lane !
That means the issue come from the SAI configuration.
There is this diagram in the SAI documentation.
TX_DATA2 is used for sai_rxdata2 if "obe" is 0 but there is no information about this "obe". My thought was that it is configured by register TCR4 on bits TCE "Transmit Channel Enable"
And as I posted TCR4 is 0x10010f3b so TCE is 0x1 (TX0 enable, other are disabled)
Any information about that ?
1,042件の閲覧回数
eric_delanghe
Also you said that " It is not possible to have hard pull-down in this case."
We already tried to remove it and it does not help
1,015件の閲覧回数
mike_susen
Hi @eric_delanghe
what about GPIO_DISP_B2_00? do you see same behavior also on tis pin?
Mike
1,009件の閲覧回数
eric_delanghe
Hello @mike_susen ,
We don't actually have DAB feature implemented.
But I'll ask hardware guys to patch my board to get FM data on GPIO_DISP_B2_00.
I will also ask hardware guys to connect the microphone (currently GPIO_DISP_B2_06) on GPIO_DISP_B2_01.
Eric
1,118件の閲覧回数
rastislav_pavlanin
Hi @mike_susen ,
could you please take this request?
thanks.
regards
R.
