Nand boot with u-boot 2013.04 on i.mx6 SOLO
939 次查看
manjunathjoshi
Hello All,
I am trying to upgrade from u-boot 2009.08 to u-boot 2013.04 so that USB support is possible at u-boot. But now the situation is, USB is working but not NAND at u-boot.
Can anybody help???
U-Boot 2013.07-svn121 (Sep 29 2015 - 14:40:53)
CPU:   Freescale i.MX6SOLO rev1.1 at 792 MHz
Reset cause: POR
Board: ihm_visio7
DRAM:  512 MiB
NAND:   0 MiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
MMC: no card present
MMC init failed
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
U-Boot >
U-Boot > nand info
U-Boot >
U-Boot >
Manju
标签 (2)
4 回复数
556 次查看
HI Manjunath
nand is supported for configuration of Sabre AI boards, like uboot.../configs/mx6qsabreauto.h
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=RDIMX6SABREAUTO&fpsp=1&tab=Documentat...
also it is useful to check pinctrl driver for nand pins usage.
556 次查看
manjunathjoshi
Hello Igor,
In u-boot-2013.04 source i am searching for Nand keyword which is not present in  include/configs/mx6qsabreauto.h. or include/configs/mx6qsabre-common.h Is there any other name that it is configured with?
I searched for mtd as well. No where i am able to see Nand related configuration. Can you please let me know what is it that is enabling Nand as a boot device.
Manju
556 次查看
Hi Manju
attached mx6qsabreauto.h,mx6qsabre_common.h,mx6qsabreauto.c (../board/freescale/mx6qsabreauto)
have definition
CONFIG_SYS_USE_NAND
556 次查看
fabio_estevam
This commit adds NAND support for mx6sabreauto boards:
git.denx.de Git - u-boot.git/commitdiff
Please use a more recent U-boot version.
Fabio Estevam
