Mx6q_sabresd Uboot unable to load bmp
406 次查看
Mcgull
Pertaining to the link below:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Patch-to-support-uboot-logo-keep-from-ub...
How do I know the patch has been applied successfully? And then how do I load the custom splash during uboot process (before linux startup)
Do I need to rebuild kernel image, becos I m only able to build uboot.bin only (due to some hardware issue). Is only uboot.bin sufficient?
@qiang_li-mpu_se
353 次查看
joanxie
if your uboot logo keep from uboot to kernel, which means your patch is available, if you use the kernel patch, you need to rebuild kernel again
