Mx6q_sabresd Uboot unable to load bmp
403件の閲覧回数
Mcgull
Pertaining to the link below:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Patch-to-support-uboot-logo-keep-from-ub...
How do I know the patch has been applied successfully? And then how do I load the custom splash during uboot process (before linux startup)
Do I need to rebuild kernel image, becos I m only able to build uboot.bin only (due to some hardware issue). Is only uboot.bin sufficient?
@qiang_li-mpu_se
350件の閲覧回数
joanxie
if your uboot logo keep from uboot to kernel, which means your patch is available, if you use the kernel patch, you need to rebuild kernel again
