Multiple Shells? - Virtualisation - IVSHMEM demo
neo2
How do I start multiple shells for the  IVSHMEM demo?
"uio_read and uio_send need to be started in different shells."
I have Hyperterminal on COM3 where I start U-boot and run jh_mmcboot
"Open two shells, using SSH to log into the board. Execute uio_read in one shell and execute uio_send in the other shell.
#uio_send /dev/uio0 [count] 0 0
#uio_read /dev/uio0 [count]"
neo2
I've figured out how to connect a SSH shell using the Ethernet port on the i.MX8 eval board.
In the COM port shell
$ ifconfig eth0 up
$ ifconfig
Look for the IP address after inet addr
e.g.
eth0 Link encap:Ethernet HWaddr 00:04:9f:07:15:9a
inet addr:169.254.42.78 Bcast:169.254.255.255 Mask:255.255.0.0
Then I start another terminal e.g. I'm using Tera Term to the IP address above 169.254.42.78
The username is root
flobro
Where are the "uio*" executables? They are not in the LF_v5.15.32-2.0.0_images_IMX8MQEVK download, but I got the Linux jailhouse demo working (after some work).
Is someone going to update the IMXVIRTUG document?
Zhiming_Liu
You can use ssh connection to open second shell
neo2
Does this mean I use an Ethernet port to ssh into the i.MX8 board rather than the serial port?
Or this can be done using the existing COM4 port?
neo2
$ ifconfig eth0 up
$ ifconfig
e.g.
