Mongodb under Imx8
Mongodb under Imx8
550 次查看
arslan
Hello everyone,
I am integrating yocto (hardknott) for a variscite based board (Imx8qxp), where we also need mongodb. I already built mongodb in differen 4.x versions, which are ported from different yocto releases. Build process runs smoothly and an image is always generated successfully.
But trying to run mongod or mongos always results in a "segmentation fault".
Could anyone integrate and run mongodb under imx8 succesfully?
标记 (3)
531 次查看
arslan
Hello @Zhiming_Liu
I only have the Imx8qxp, where I can run it.
535 次查看
Zhiming_Liu
Hi @arslan
Have you tried other platform, like i.MX8M series?
Best Regards
Zhiming
503 次查看
arslan
Hello @Zhiming_Liu
Meanwhile I managed to test also under Imx8mp: we had the same results. We tested under mp and qx several 4.x mongodb versions, everytime building goes smoothly, attempt to run mongod or mongos results immediately in a seg fault.
I also built everything for a raspberry pi 4, everything works under raspi.
