Mipi display auto-rotate with weston-wayland
897件の閲覧回数
Hardevsinh_Palaniya
I am using MIPI-DSI display with i.MX8M mini. U-boot and kernel are as follow.
  • U-boot : U-Boot 2020.04-5.4.47-2.2.0
  • Kernel : 5.4.47 (NXP i.MX Release Distro 5.4-zeus)
I am able to bring-up the display and rotate it using weston.ini . Now, i want to rotate the display with the input of accelerometer and gyroscope.
Can any share the documents or example for auto-rotate display with weston-wayland?
Senior Embedded Engineer | hardevsinh.palaniya@siliconsignals.io | www.siliconsignals.io
872件の閲覧回数
Hardevsinh_Palaniya
Hi @Zhiming_Liu ,
Thanks for the reply.
I used weston_output_set_transform as you suggested, and it required resetting the display in order to apply the rotation.
Can you suggest any thing like xrandr used for X11?
884件の閲覧回数
Zhiming_Liu
We don't have such document or demo code for weston.
You can add thread to listen accelerometer data and use  weston_output_set_transform change the display orientation
