Hey Aldo,
Thank you for taking the time to respond to my queries. I am sorry for a delayed response on your questions.This only happens when i use the rpmsg feature, if I use the normal version I do not observe this issue.
A reiteration of the steps I have taken to build my custom images to be used for an application I have been working on :
1.I have made changes in the defconfig used for my project.
2.I have also accordingly tried to make changes in the dts file linked to the dtbo image.
3.I then build the kernel, other images and load them onto the imx8mn using uuu.
TIA,
Anurag
