MSI Interrupt is not generating in I.MX8QM board
640件の閲覧回数
mallibeerala
I am configuring my I.MX8QM board as Root complex and my custom board is configured as endpoint.
I am able to write & read PCIe data between I.MX8QM board and my custom board.
Now I am trying MSI interrupt, MSI interrupt address and data mentioned as "0xbc000000, 0", I got these values in RC by using command "lspci -vv"
for testing msi interrupt generation, In I.MX8QM board I am writing 0 data into 0xbc000000 address location but I didn't get any msi interrupt.
Here MSI address is belongs ddr space, Is it OK.
Same procedure I am following in my layerscape board, there address and data mentioned as "0x15800000 and 0" and it is not in the ddr memory range and I am getting MSI interrupt while writing 0 into 0x15800000 address location.
Please help us to resolve this Issue.
Thanks & Regards,
Mallikarjuna
6 返答(返信)
621件の閲覧回数
jimmychan
Could you tell me which version of BSP are you using?
618件の閲覧回数
mallibeerala
I am using kernel version - 5.15.32, which is lts.
596件の閲覧回数
jimmychan
Please refer to the iMX reference manual page 90. There is the memory layout of i.MX8QM pcie.
https://www.nxp.com/docs/en/reference-manual/IMX_REFERENCE_MANUAL.pdf
575件の閲覧回数
mallibeerala
In Reference manual memory layout mentioned as below but MSI address is not available in below address region, it is available at 0xbc000000.
PCIeA
– PCIe host configuration space: 0x5f00_0000 – 0x5f00_ffff (64K bytes)
– PCIe device configuration space: 0x6ff0_0000 – 0x6ff7_ffff (512K bytes)
– PCIe IO space: 0x6ff8_0000 – 0x6ff8_ffff (64K bytes)
– PCIe memory space: 0x6000_0000 – 0x6fef_ffff (255M bytes)
Mallikarjuna
552件の閲覧回数
jimmychan
525件の閲覧回数
mallibeerala
Please provide example for I.MX8QM board, vector address is different for I.MX8QM and I.MX6 board.
Thanks & Regards,
Mallikarjuna
