MCUXpresso: usage of FLEXSPI_TransferNonBlocking API with iMX8QXP
935件の閲覧回数
pierluigi_p
Contributor V
Hi all,
surfing MCUXpresso documentation and source code, in file
    devices/MIMX8QX6/drivers/fsl_flexspi.c
You can find the API
The notes recommend using the function
    FLEXSPI_GetTransferCount
in order to poll the transfer status, however this seems to be not available in MCUXpresso.
Is there any sample reference code showing how to actually use FLEXSPI_TransferNonBlocking API?
Pier
922件の閲覧回数
AldoG
I'm afraid there is not, as you may know the only example we have available using FSPI in SDK is the Octal example which uses polling transfers.
Aldo.
923件の閲覧回数
AldoG
Aldo.
