MCIMXHDMICARD schematics?
搜索替代
1,557 次查看
enaud
Hi all,
I bought from the site of Frescale the mcimxhdmicard, but i need schematics and datasheet because i want use Camera Sensor Input for to have GPIO.
Where are schematics?
1,066 次查看
tomášbenda
I found schematics for MCIMXHDMICARD on google ;-) Files can be downloaded here:http://www.element14.com/community/docs/DOC-39391/l/freescale-imx53-based-mcimx53-start-quick-start-...
Tom
6 回复数
1,067 次查看
tomášbenda
Tom
1,066 次查看
enaud
I need CSI0_DATx for to use them like GPIO.. How i can take this Signal in MCIMXHDMICARD?
1,066 次查看
tomášbenda
If you look at schematic of HDMI board (page 2), you can see that pins 44 and 46 of expansion connector are named as SD0 and WS. The same pins are connected to CSIO_DAT16 and CSIO_DAT17 at the i.MX53 Quick Start Board - R.
I don't have MCIMXHDMICARD at home, but from schematic I am expected, that you have to populate R150 and R151 on the MCIMXHDMICARD.
I hope that my reply is answer to your question ;-)
1,066 次查看
enaud
and for CSIO_DAT12,13,14,15 ecc..?
1,066 次查看
tomášbenda
Download and unzip this package: Freescale: i.MX53 QuickStart Board Design File for HDMI Board - element14
There is PDF document with schematics. Pins 26, 28, 32, 34, 56 and 58 of expansion connector on the HDMI card side aren't connect. These appropriate pins means signals (in the same order) CSIO_DAT12, CSIO_DAT13, CSIO_DAT14, CSIO_DAT15, CSIO_DAT18 and CSIO_DAT19.
Thus, it's impossible to use those signals at HDMI board :-(
1,066 次查看
enaud
I can use others GPIO like
CONN_DISP1_DAT0.... CONN_DISP1_DAT23?
But I note that are connected to HDMI Trasmitter and R121....R147 are not welded...
On PCB where are SD0 and WS?
What I must do?
