MCIMX6Q-SDB the network LED not light
The network LED not light while he power and the network are connected. the LED will flash a few times when he connected the power and always turn on after inseted into the networl cable
he config the IP and not found?
so could you help to check and advise ?
Does the board boot up success?
Hi Rata
Our customer maybe a novice, he don’t know what is the BSP.
Could you help to asked them how to check it?
Thanks& Regards.
Abing
GC Technical Support
Your Source for Engineering Solutions "Design Center"
Visit our website - https://www.element14.com/ref_TS_56
Here you need to let your customer confirm the network he use is work well. And he can change one net cable or router.
Hi Abing,
You can ask them which images they download to this board? And they want to boot up from SD card or emmc?
Have a nice day
Rita
Hi Abing zhang,
Could you tell me which version BSP running on the MCIMX6Q-SDB board?
Have a nice day
Rita
