MCIMX287CVM4B MCIMX287CVM4C
862 次查看
E_Badillo
Can anyone tell me what is the difference between MCIMX287CVM4B and MCIMX287CVM4C? Why they have different suffix?
I have tried to look for this in the datasheet but cannot found.
iMX287
836 次查看
JosephAtNXP
The difference in the architecture and peripherals does not exist,
The only difference is that the B is not recommended for new designs, is not discontinued yet and the C is recommended for new designs and therefore available.
As mentioned before, there are different silicon revisions, which improve erratas found in the silicon rev before (i.e. B)
6 回复数
837 次查看
JosephAtNXP
807 次查看
E_Badillo
Thanks for your response.
851 次查看
samsaprunoff
Contributor V
Good day,
I have not looked at the Datasheet, but typically the suffix on NXP's parts relate to the part's version and/or mask set.  In other words NXP makes running changes to their parts to address issues, erratas, etc and so they mark their parts accordingly as newer versions of the parts are released.
Cheers,
Sam
809 次查看
E_Badillo
Thanks for your response, I want to replace the B version with the C version, so I just want to know if it is necessary to modify the firmware in order to have this component working without issues.
798 次查看
samsaprunoff
Contributor V
Good day,
To see if any firmware changes are needed on your side, check the device's errata documents.  The errata documents will list the various changes and/or bugs and/or workarounds that were addressed or are outstanding on the part and/or part's revision.
Cheers,
Sam
791 次查看
E_Badillo
Thanks, I will take a look at the publication.
