LWIP bare-metal ethernetif_input() thread safe
602件の閲覧回数
mspenard603
Hi All,
 I have a bare-metal project with LWIP and Eth being serviced (i.e., ethernetif_input() ) in mail() loop as is recommended per the SDK example and notes I've read. Viz., it is my understanding that ethernetif_input() is not to run in an interrupt context.
My issue with with LWIP and Eth not being serviced quick enough. As I have some GUI code (EwWiz) that inserts enough delay as to lag network io to some large degree.
Therefore, I'm looking for some way to run ethernetif_input() off a GPT based timer. How can I make it interrupt context safe?
589件の閲覧回数
jeremyzhou
Hi @mspenard603 ,
In my opinion, I'd highly recommend you use the LWIP+ FreeRTOS demo as the template, which can manage the incoming ENET frame, meanwhile, synchronize the signal with the GUI code.
And you can find the LWIP+ FreeRTOS demo in the SDK library.
TIC
573件の閲覧回数
mspenard603
Thanks. Were a bit far into our bare-metal project. So RTOS isn't on the table for now.
I did find a solution by utilizing the PIT. And a lock-out mechanism for when it shouldn't run. E.g., in the middle of an f_open() or f_read() etc etc.
Ethernet speeds jumped 10 fold to where they should be.
