LTIB LIBMPEG2 Compilation Error
次の代わりに検索
1,907件の閲覧回数
stevezilla
I downloaded the latest BSP and am attempting to create image using LTIB.  I have selected the libmpeg2 package which is causing the error below.  Searching Google I have been unable to find anyone else which has had a similar issue, does anyone have guidance on a resolution?  Output is below:
/bin/bash ../../libtool --tag=CC --mode=link gcc -Wall -g  -O3 -fomit-frame-pointer -fno-common -prefer-non-pic-o libmpeg2convert.la -rpath /usr/lib -no-undefined rgb.lo uyvy.lo libmpeg2convertarch.la
gcc -shared  .libs/rgb.o .libs/uyvy.o -Wl,--whole-archive ./.libs/libmpeg2convertarch.a -Wl,--no-whole-archive   -Wl,-soname -Wl,libmpeg2convert.so.0 -o .libs/libmpeg2convert.so.0.0.0
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: .libs/rgb.o: relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
.libs/rgb.o: could not read symbols: Bad value
collect2: ld returned 1 exit status
make[2]: *** [libmpeg2convert.la] Error 1
make[2]: Leaving directory `/home/steve/ltib/ltib/rpm/BUILD/mpeg2dec-0.4.1/libmpeg2/convert'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/steve/ltib/ltib/rpm/BUILD/mpeg2dec-0.4.1/libmpeg2'
make: *** [all-recursive] Error 1
error: Bad exit status from /home/steve/ltib/ltib/tmp/rpm-tmp.7157 (%build)
RPM build errors:
Build time for libmpeg2: 14 seconds
Failed building libmpeg2
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Mon May 20 08:20:33 2013
Ended:   Mon May 20 08:20:51 2013
Elapsed: 18 seconds
These packages failed to build:
libmpeg2
Build Failed
Exiting on error or interrupt
ラベル(3)
タグ(4)
539件の閲覧回数
GraceH
Senior Contributor II
Hi all,
After run ./ltib -p libmpeg2 -m prep, remove "-prefer-non-pic" from "ltib/rpm/BUILD/mpeg2dec-0.4.1/configure", I can build libmpeg2 successfully.
LIBMPEG2_CFLAGS="$LIBMPEG2_CFLAGS -prefer-non-pic"
LIBMPEG2_CFLAGS="$LIBMPEG2_CFLAGS"
Grace
4 返答(返信)
539件の閲覧回数
LeonardoSandova
Specialist I
Steve,
As suggested by the log, can you modify the corresponding spec (dist/lfs-5.1/libmpeg2/libmpeg2.spec) and add –fPIC in the Build step? Not sure if this will work but give it a try.
Leo
539件の閲覧回数
richagoel
I am having the same problem building libmpeg2.The solution suggested by Leonardo didnt work!
540件の閲覧回数
GraceH
Hi all,
Grace
539件の閲覧回数
lancejump
I am having the same problem with openobex (see openobex link with libusb fails: relocation R_ARM_MOVW_ABS_NC) Has anyone solved this yet?
