[LGE-CTO] booting failure with 4G DRAM with OPTE
搜索替代
1,028 次查看
Jessie_Lee
Hi @haidong_zheng
customer is LGE-CTO
project is IFE (In Flight Entertainment)
silicon : i.MX8MQ
BSP : L5.4.70.
issue : customer met booting failure with suck at "starting kernel ...." log.
customer applied below patch and with ddr_timing.c from ddr stress tool.
with below patch + removed OPTEE ==> 4G booting is okay and also 4G memory seems to be okay on target board.
But, below patch + OPTEE , customer met booting failure  with stuck at "starting kernel.."
diff -urN a/arch/arm/dts/imx8mq-evk.dts b/arch/arm/dts/imx8mq-evk.dts
--- a/arch/arm/dts/imx8mq-evk.dts   2021-01-26 08:40:48.957563246 +0900
+++ b/arch/arm/dts/imx8mq-evk.dts   2021-01-26 08:45:05.274299618 +0900
@@ -29,7 +29,8 @@
    memory@40000000 {
        device_type = "memory";
-       reg = <0x00000000 0x40000000 0 0xc0000000>;
+       reg = <0x0 0x40000000 0 0xc0000000>,
+              <0x1 0x00000000 0 0x40000000>;
    pcie0_refclk: pcie0-refclk {
  1. config.h ‘s 4G
diff -urN a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig
--- a/configs/imx8mq_evk_defconfig  2021-01-25 10:51:45.397639290 +0900
+++ b/configs/imx8mq_evk_defconfig  2021-01-25 11:31:02.699624338 +0900
@@ -17,6 +17,7 @@
 CONFIG_ARCH_MISC_INIT=y
 CONFIG_SPL_MMC_SUPPORT=y
 CONFIG_SPL_SERIAL_SUPPORT=y
+CONFIG_NR_DRAM_BANKS=2
 CONFIG_SPL_DRIVERS_MISC_SUPPORT=y
 CONFIG_SPL=y
 CONFIG_CSF_SIZE=0x2000
diff -urN a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h
--- a/include/configs/imx8mq_evk.h  2021-01-25 10:51:45.489638119 +0900
+++ b/include/configs/imx8mq_evk.h  2021-01-25 11:31:02.783623269 +0900
@@ -171,7 +171,10 @@
 #define CONFIG_SYS_SDRAM_BASE           0x40000000
 #define PHYS_SDRAM                      0x40000000
-#define PHYS_SDRAM_SIZE            0xC0000000 /* 3GB DDR */
+#define PHYS_SDRAM_SIZE             0xc0000000 /* 3GB */
+#define PHYS_SDRAM_2                0x100000000
+#define PHYS_SDRAM_2_SIZE              0x40000000 /*     */
below is bdinfo with  booting failure. i am not sure but does below glue text address is as below. it is for your reference.
u-boot=> bdinfo
arch_number = 0x0000000000000000
boot_params = 0x0000000000000000
DRAM bank = 0x0000000000000000
-> start = 0x0000000040000000
-> size = 0x00000000be000000
DRAM bank = 0x0000000000000001
-> start = 0x0000000100000000
-> size = 0x0000000040000000
baudrate = 115200 bps
TLB addr = 0x00000000fdff0000
relocaddr = 0x00000000fd725000
reloc off = 0x00000000bd525000
irq_sp = 0x00000000fd11c490
sp start = 0x00000000fd11c490
FB base = 0x0000000000000000
Early malloc usage: ae8 / 2000
fdt_blob = 0x00000000fd11c4a8
u-boot=>
Could you please check this issue and help me to find any clue?
Thank you
BRs
jessie
1,007 次查看
haidong_zheng
@Jessie_Lee :
We had a way to support 8MQ 4GB memory without changing OPTEE load address.
Please refer to: https://community.nxp.com/t5/iMX-and-Vybrid-Support/8M-Scale-845-850-board-4GB-memory-support-summar...
5 回复数
390 次查看
kevin_fu
Hi @haidong_zheng
I have similar DDR issue, could you share this patch for me
thanks!
375 次查看
haidong_zheng
Hi @kevin_fu :
I don't know what's your exact request, any way I past below for your reference:
ifneq (,$(filter $(PLATFORM_FLAVOR),mx8mqevk))
-CFG_DDR_SIZE ?= 0xc0000000
+CFG_DDR_SIZE ?= 0x100000000
+CFG_TZDRAM_START ?= 0xfe000000
CFG_UART_BASE ?= UART1_BASE
+$(call force,CFG_CORE_LARGE_PHYS_ADDR,y)
+$(call force,CFG_CORE_ARM64_PA_BITS,36)
endif
1,008 次查看
haidong_zheng
@Jessie_Lee :
923 次查看
aber
Jessie_Lee :
     Can you share the link? No access。
You do not have sufficient privileges for this resource or its parent to perform this action. Click your browser's Back button to continue.
989 次查看
Jessie_Lee
Hi @haidong_zheng
Thank you for your help
BRs
jessie
