LCD turning white after a few minutes
Search instead for
erezsteinberg
Hi all-
I have some strange behavior on my board and LCD
It's a custom iMX6S board running Linux 3.0.35. The display is a parallel LCD (8-bit) using BT656 protocol.
After booting, I display an image on the LCD. After a few minutes the display suddenly becomes white. At that point, if I try to display a new image nothing happens.
However, if I do "echo 0 > /sys/devices/platform/mxc_sdc_fb.0/graphics/fb0/blank", then I can display images again. But, again, after a few minutes the LCD turns white.
Any ideas what might be causing the LCD to 'turn white' by itself?
Sincerely,
Erez
Labels (3)
igorpadykov
Hi Erez
one can try to turn off LCD blanking also with
echo -e "\033[9;0]" > /dev/tty0
https://community.freescale.com/message/432351#432351
igorpadykov
Hi Erez
erezsteinberg
Hi Igor,
Thanks -- that solved the issue.
I found this resource with additional useful commands --- http://www.armadeus.com/wiki/index.php?title=FrameBuffer
For anyone looking::
  • To stop blinking cursor:
# echo 0 > /sys/class/graphics/fbcon/cursor_blink
also possible at boot time (with 3.x recent kernels):
BIOS> setenv extrabootargs vt.global_cursor_default=0
  • To make it blinking again:
 # echo 1 > /sys/class/graphics/fbcon/cursor_blink
  • To grab a screenshot of a running Framebuffer application, use FBGrab
  • To enter in Framebuffer sleep mode:
# echo 1 > /sys/class/graphics/fb0/blank
  • To leave Framebuffer sleep power mode:
 # echo 0 > /sys/class/graphics/fb0/blank
  • To set "sleep mode"/screensaver entering time (where X is a time in minute; 0 = never):
# echo -e '\033[9;X]' > /dev/tty1 (from serial console)
or
 # echo -e '\033[9;X]'    (from framebuffer console)
or to set it at each boot, use /etc/inittab:
 tty1::sysinit:echo -e '\033[9;X]'
Other usefull ESC sequences
  • To (definitly) hide cursor:
 # echo -e '\033[?17;0;0c' > /dev/tty1    (from serial console)
or
 # echo -e '\033[?17;0;0c'    (from framebuffer console)
  • inverse screen on:
# echo -e '\033[?5h' > /dev/tty1
  • inverse screen off:
 # echo -e '\033[?5l' > /dev/tty1
Erez
