JTAG_MOD
Search instead for
JTAG_MOD
neusch
i selected JTAG_MOD = 0 in Hardware to debug i.MX6:
To check the placement, a boundary scan IEEEE1149.1 will be needed.
It is not possible to populate or unpopulate the pull-down resistor at the pin JTAG_MOD.
Is it possible to select SJC only in Register or otherwise?
Is SW debug and boundary scan possible with the same Hardware?
thanks for your Information,
Mathias
igorpadykov
this is unfortunately not possible. Also one can refer
to i.MX6 System Development User’s Guide
http://cache.freescale.com/files/32bit/doc/user_guide/IMX6DQ6SDLHDG.pdf
if you have special questions for boundary scan expert
suggest to elevate that using local fae channel
neusch
Is a boundary scan test possible, when the state of JTAG Controller JTAG_MOD = 0 ?
I think a question for a boundary scan expert.
Thank you Igor
igorpadykov
igorpadykov
Hi Mathias
unfortunately JTAG_MOD state can not be changed from software,
so seems sw debug and boundary scan can not be possible with
the same hardware.
