Is there a QT app to display network strength?
962 次查看
sujay1
Contributor V
I am using yocto BSP with qt5.9.
I need an app that can display the network strength.
In Android we get this on the top left denoted by 4 lines (number of lines depend on signal strength).
is there any app we can run for the similar effect on yocto?
标记 (3)
830 次查看
karangajjar
Senior Contributor II
Hi Sujay S,
There is no particular example for showing the signal strength in qt5 imx image. However you can have a look at examples under qt5/examples/network
Also, you can build one simple application to check out the signal strength and cross compile for imx platform.
Please follow below document for more information:
Enable QT developement for i.MX6UL
Building QT for i.MX6
Karan Gajjar
830 次查看
b36401
We have no such utility.
However you can write simple QT application to run iperf (commandline network benchmark).
831 次查看
karangajjar
Hi Sujay S,
Karan Gajjar
