Is that possible to flash Arm Trusted Firmware(ATF) without uboot?
If it is possible, what are the steps i have to follow?
Solved! Go to Solution.
Hi @Hariharan1,
Thank you for contacting NXP Support.
Based on the following official documentation from Trusted Firmware, the TF-A binary is combined with U-Boot. Therefore, using the NXP Tools to build the firmware you can't flash only this one.
7.21. NXP i.MX 8M Series — Trusted Firmware-A 2.10.0 documentation
I hope this information will be helpful.
Have a great day!
Hi @Hariharan1,
Have a great day!
