Is there any reference document which explain connections between imx6 and WM8978 audio codec.
SHAMMI
Hi SHAMMI
this depends which audio interface is used, please check SSI connections
description in AN2628 Programming Audio Applications
http://www.nxp.com/docs/en/application-note/AN2628.pdf
or for SAI : AN4486
http://www.nxp.com/assets/documents/data/en/application-notes/AN4486.pdf
ESAI : AN18148
http://www.nxp.com/docs/en/application-note/AN1848.pdf
